Exception type:System.NullReferenceException
Exception message:Object reference not set to an instance of an object.
Exception source:VideoOS.Toolkit
Exception Target Site: AddReferenceToSurface
at VideoOS.Toolkit.RendererToolkit.AddReferenceToSurface(IntPtr object)
at VideoOS.UI.Common.WPF.VideoPlayer.Toolkit.ToolkitWrapper.AddReferenceToSurface(IntPtr surfacePointer)
at VideoOS.UI.Common.WPF.VideoPlayer.Toolkit.VideoImage.VideoImageManager._toolkitWrapper_RenderedDataAvailable(Object sender, RenderInformationEventArgs e)
at System.EventHandler`1.Invoke(Object sender, TEventArgs e)
at VideoOS.UI.Common.WPF.VideoPlayer.Toolkit.ToolkitWrapper.HandleRenderedData(Dictionary`2 renderingInformation)
at VideoOS.Toolkit.CmRenderingHandler.HandleRenderedData(CmRenderingHandler* , map<int\,std::shared_ptr<NmToolkit::ImRendererToolkit::ImRenderingInformation const >\,std::less\,std::allocator<std::pair<int const \,std::shared_ptr<NmToolkit::ImRendererToolkit::ImRenderingInformation const > > > >* renderingInformation)
