Smart Clients newer than 2024 R2 are unable to connect to management server patched with Milestone.Hotfix.202609230709.MS.24.2.14120.3008
This is not directly related to development but, I was asked to post here related to an ongoing technical support chase.
The scenario is that after applying the management hotfix Milestone.Hotfix.202609230709.MS.24.2.14120.3008, Smart Clients NEWER than 2024 R2 cannot connect to the patched management server. Clients OLDER or at 2024 R2 can connect. The error is simply ‘Login failed due to an unknown error’.
Question for the Milestone folks. Is this by design? It presents a limitation in which I now cannot upgrade smart clients in our organization past 2024 R2 until such time at which all of our deployed systems have been upgraded past this version. This due to users interacting with multiple separate instances of Milestone.
Any feedback is appreciated.
This question is specifically about Milestone XProtect® functionality and does not appear to relate to integration development, which is the main focus of this forum.
I’m therefore not sure this was the right place for Milestone Support to direct you. I hope the ongoing support case provides you with the full answer you need.
Thanks for the response. I assumed as much.
