SmartMap integration
I want to add marker / indicator on SmartMap? Is it possible ?
This below example didn’t help me.
https://doc.developer.milestonesys.com/html/samples/SmartMapControl.html
Thanks.
If this is a about regular setup of Smart Map you might find this useful.
https://developer.milestonesys.com/s/article/Smart-Map-setup-guide
You can define MIP item and these can be added to the Smart Map. See the Sensor Monitor sample.
https://doc.developer.milestonesys.com/html/index.html?base=samples/sensormonitor_sample.html&tree=tree_1.html
If this does not fit please explain what it is that you want to add to the Smart Map.
