I am able to call simple SOAP Methods in Milestone corporate like GetVersion.
When I try to submit date I get FaultException 1.
Example:
POST http://10.11.64.96/ServerAPI/ServerCommandService.asmx HTTP/1.1
Accept-Encoding: gzip,deflate
Content-Type: text/xml;charset=UTF-8
SOAPAction: “http://videoos.net/2/XProtectCSServerCommand/BookmarkCreate ”
Content-Length: 572
Host: 10.11.64.96
Connection: Keep-Alive
User-Agent: Apache-HttpClient/4.1.1 (java 1.5)
Authorization: NTLM TlRMTVNTUAADAAAAGAAYAEAAAAC0ALQAWAAAABoAGgAMAQAAGgAaACYBAAAcABwAQAEAAAAAAABcAQAANQIIIBoNwbP5rDtomm7p60zWvJIEJej0PYQ7PAkJ/sfIpmOceLbFSV0SwygBAQAAAAAAANAgrN3jptUBBCXo9D2EOzwAAAAAAgAaAFAAVABQAEQANAAwADkAMABDAEEATQAwADEAAQAaAFAAVABQAEQANAAwADkAMABDAEEATQAwADEABAAaAFAAVABQAEQANAAwADkAMABDAEEATQAwADEAAwAaAFAAVABQAEQANAAwADkAMABDAEEATQAwADEABwAIAMNofvbjptUBAAAAAFAAVABQAEQANAAwADkAMABDAEEATQAwADEAQQBkAG0AaQBuAGkAcwB0AHIAYQB0AG8AcgBQAFQASgBNAFIAMwAwADAAMQAxADQAMQBOAEIA
<soapenv:Envelope xmlns:soapenv=“http://schemas.xmlsoap.org/soap/envelope/ ” xmlns:xpr=“http://videoos.net/2/XProtectCSServerCommand ”>
soapenv:Header/
soapenv:Body
xpr:BookmarkCreate
<xpr:deviceId>7436a420-00a9-420e-a6d7-7ec35e0b2ebc</xpr:deviceId>
<xpr:timeBegin>2019-11-29T17:00:00Z</xpr:timeBegin>
<xpr:timeTrigged>2019-11-29T17:00:01Z</xpr:timeTrigged>
<xpr:timeEnd>2019-11-29T17:01:00Z</xpr:timeEnd>
<xpr:description>Ola</xpr:description>
</xpr:BookmarkCreate>
</soapenv:Body>
</soapenv:Envelope>
Response
<soap:Envelope xmlns:soap=“http://schemas.xmlsoap.org/soap/envelope/ ” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance ” xmlns:xsd=“http://www.w3.org/2001/XMLSchema ”>
soap:Body
soap:Fault
<faultcode>soap:Server</faultcode>
<faultstring>Server was unable to process request. ---> Invalid name character in 'FaultException\`1'.</faultstring>
<detail/>
</soap:Fault>
</soap:Body>
</soap:Envelope>
Can you help?
Thank You
Rik
December 4, 2019, 2:13pm
2
Hello Rie,
Thank you for the answer.
However, I do not want to use external code. [which I am struggling to compile]
Can you give me a SOAP example that should work? For example, for SOAPUI Builder?
Thanks.
RT
Rik
December 9, 2019, 12:22pm
4
You must do login. TCP video viewer sample can show you this.
https://doc.developer.milestonesys.com/html/index.html?base=samples/tcpviewer_sample.html&tree=tree_search.html?search=tcp+video+viewer
This sample do not work as a SOAPUI. Unfortunately, Milestone have no sample with SOAPUI.
Hello, I was able to sort this out. I leave some SOAP UI example to help others
Login to Milestone
POST http://10.11.65.61/ServerAPI/ServerCommandService.asmx HTTP/1.1
soapenv:Header/
soapenv:Body
xpr:Login
<xpr:instanceId>d10a7c21-5afa-4e4b-8270-e278035de3e9</xpr:instanceId>
<xpr:currentToken></xpr:currentToken>
</xpr:Login>
</soapenv:Body>
</soapenv:Envelope>
Configure NTLM authentication with username/password/Milestone_servername.
The response should be like this
soap:Body
<LoginResult>
<Token>TOKEN#369422dd-9ddc-1234-aaf6-30846e771eba#srv01milpdoeira//ServerConnector#</Token>
<RegistrationTime>2019-12-18T16:49:06.33Z</RegistrationTime>
<TimeToLive>
<MicroSeconds>14400000000</MicroSeconds>
</TimeToLive>
<TimeToLiveLimited>false</TimeToLiveLimited>
</LoginResult>
</soap:Body>
</soap:Envelope>
Use the following command to create a bookmark
soapenv:Header/
soapenv:Body
xpr:BookmarkCreate
**<!--Not Optional! It is the Token from the previous response-->**
<xpr:token>TOKEN#369422dd-9ddc-1234-aaf6-30846e771eba#srv01milpdoeira//ServerConnector#</xpr:token>
**<!--Guid of the camera. It can be obtained in Milestone Management Client (search in google)-->**
<xpr:deviceId>338F3BAE-59AB-4FF5-BABA-D0AE39317CCE</xpr:deviceId>
<xpr:timeBegin>2019-12-18T13:05:00Z</xpr:timeBegin>
<xpr:timeTrigged>2019-12-18T13:05:00Z</xpr:timeTrigged>
<xpr:timeEnd>2019-12-18T13:05:00Z</xpr:timeEnd>
<!--Optional:-->
<xpr:reference>Reference 4</xpr:reference>
<!--Optional:-->
<xpr:header>header 4</xpr:header>
<!--Optional:-->
<xpr:description>Description 4</xpr:description>
</soapenv:Body>
</soapenv:Envelope>
Sample response
soap:Body
<BookmarkCreateResult>
<Id>65b1886d-8ca8-4772-a9d6-3643208fe5cd</Id>
<DeviceId>338f3bae-59ab-4ff5-baba-d0ae39317cce</DeviceId>
<Reference>Reference 4</Reference>
<Header>header 4</Header>
<Description>Description 4</Description>
<User>SRV01MILPDOEIRA\\USER</User>
<TimeBegin>2019-12-18T13:05:00Z</TimeBegin>
<TimeTrigged>2019-12-18T13:05:00Z</TimeTrigged>
<TimeEnd>2019-12-18T13:05:00Z</TimeEnd>
</BookmarkCreateResult>
</soap:Body>
</soap:Envelope>
Access milestone client to search the bookmark. Make sure the user you are using has access to bookmarks (if not, the bookmarks are in milestone but you cannot see them)
