I’ve done other test on a different site with a different Edition of Milestone. After 4/5 correctly exported video I’m having the same issue.
These are the log of this system:
2021-05-17;08:12:10;Info;LicenseWrapper;CheckTwoStepVerification is False
2021-05-17;08:12:11;Info;LicenseWrapper;ManageAlarms is True
2021-05-17;08:12:11;Info;CommunicationCommandQueue;LogIn; OK;admin
2021-05-17;08:12:14;Info;CommunicationManager.CheckConnectionsAreAlive();User Timed Out! ChannelID: 01c03684-4b0e-432c-8b61-f540892cda5d
2021-05-17;08:12:22;Info;CommunicationManager.CheckConnectionsAreAlive();User Timed Out! ChannelID: aa5c839d-6422-402f-9ce5-257ecc9debff
2021-05-17;08:12:28;Info;LicenseWrapper;CheckTwoStepVerification is False
2021-05-17;08:12:28;Info;LicenseWrapper;ManageAlarms is True
2021-05-17;08:12:28;Info;CommunicationCommandQueue;LogIn; OK;admin
2021-05-17;08:12:29;Info;PlaybackVideoSourceExt.VideoFetchThread;Exitted
2021-05-17;08:13:09;Info;LicenseWrapper;CheckTwoStepVerification is False
2021-05-17;08:13:10;Info;LicenseWrapper;ManageAlarms is True
2021-05-17;08:13:10;Info;CommunicationCommandQueue;LogIn; OK;admin
2021-05-17;08:13:20;Info;LicenseWrapper;CheckTwoStepVerification is False
2021-05-17;08:13:21;Info;LicenseWrapper;ManageAlarms is True
2021-05-17;08:13:21;Info;CommunicationCommandQueue;LogIn; OK;admin
2021-05-17;08:13:28;Info;CommunicationManager.CheckConnectionsAreAlive();User Timed Out! ChannelID: 3ea30349-f8ce-436b-a5ec-82a299659a5d
2021-05-17;08:13:30;Info;CommunicationManager.CheckConnectionsAreAlive();User Timed Out! ChannelID: 0411987a-2291-4f93-8ac9-441258396034
2021-05-17;08:13:36;Info;LicenseWrapper;CheckTwoStepVerification is False
2021-05-17;08:13:37;Info;LicenseWrapper;ManageAlarms is True
2021-05-17;08:13:37;Info;CommunicationCommandQueue;LogIn; OK;admin
2021-05-17;08:13:37;Info;PlaybackVideoSourceExt.VideoFetchThread;Exitted
2021-05-17;08:13:40;Info;CommunicationManager.CheckConnectionsAreAlive();User Timed Out! ChannelID: 53983146-7095-44dd-95b3-e11e751e9112
As you can see in the following images the connection and the login is correct but nothing happens.
And the live view of the camera works correctly.
I add that if I try to export from the smart client the same period it always works correctly.
Best regards
