"SqlUpdate failed" error on fresh install of XProtect Corporate 2023 R3
Good day,
I am trying to do a fresh install of XProtect Corporate 2023 R3 on my Microsoft Windows Server 2022 Standard and the milestone installer is giving me the ‘Could not configure the server. see the log file for more information.’ error.
installer log file error
12/19/2023 4:31:49 AM Information Calling SetupDatabaseTask
12/19/2023 4:33:29 AM Information Last error: {0}
12/19/2023 4:33:29 AM Error An error occurred: ‘InstallationAdapterException: Could not configure the server. See the log file for more information. —> ServerConfiguratorFailedException: Error occured while configuring the server. See log file at [C:\ProgramData\Milestone\Installer\ConfiguratorI.log](file:C:/ProgramData/Milestone/Installer/ConfiguratorI.log) for more information. —> DbUpdateException: SqlUpdate failed!’. Error details: at VideoOS.Installer.ServerConfiguratorPlugin.ConfigurationTaskInstall.DoRun()
at VideoOS.SoftwareManager.Core.Task.Task.Start()
12/19/2023 4:33:29 AM Error An error occurred: ‘ServerConfiguratorFailedException: Error occured while configuring the server. See log file at [C:\ProgramData\Milestone\Installer\ConfiguratorI.log](file:C:/ProgramData/Milestone/Installer/ConfiguratorI.log) for more information. —> DbUpdateException: SqlUpdate failed!’. Error details: at VideoOS.Installer.ServerConfiguratorPlugin.ServerConfigurator.ServerConfigure(IServerAdminLog logComponent, Int32 webSitePort, String configuratorLogPath, IKeyStorage keyStorage, Action registerManagementServer, ISqlConnectionManager managementServerSqlConnectionManager)
at VideoOS.Installer.ServerConfiguratorPlugin.ServerConfigurator.RunInstall(Boolean isHWMM, Boolean isFinalizedMode)
12/19/2023 4:33:29 AM Error An error occurred: ‘DbUpdateException: SqlUpdate failed!’. Error details: at VideoOS.Server.Admin.Tasks.SetupDatabaseTask.Install(IDatabaseConnectionInfo databaseConnectionInfoMs, IDatabaseConnectionInfo databaseConnectionInfoIdp, IDatabaseConnectionInfo databaseConnectionInfoIncidentManager, String scriptsPath, String product, String companyName, Version currentDbVersion, Boolean isExternallyManaged, Boolean shouldDeleteDatabases)
12/19/2023 4:33:29 AM Error Install failed.VideoOS.Installer.Sequencer.ErrorHandling.InstallerSequencerException: Could not configure the server. See the log file for more information. —> VideoOS.Installer.ServerConfiguratorPlugin.ServerConfiguratorFailedException: Error occured while configuring the server. See log file at [C:\ProgramData\Milestone\Installer\ConfiguratorI.log](file:C:/ProgramData/Milestone/Installer/ConfiguratorI.log) for more information. —> VideoOS.Server.Admin.Tasks.DbUpdateException: SqlUpdate failed!
— End of inner exception stack trace —
Server stack trace:
at VideoOS.Installer.Sequencer.SequenceManager.Install()
at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs)
at System.Runtime.Remoting.Messaging.StackBuilderSink.AsyncProcessMessage(IMessage msg, IMessageSink replySink)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.EndInvokeHelper(Message reqMsg, Boolean bProxyCase)
at System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(Object NotUsed, MessageData& msgData)
at VideoOS.Installer.Sequencer.SequenceManager.BeginInstallDelegate.EndInvoke(IAsyncResult result)
at VideoOS.Installer.UI.WizardPageInstall.InstallationEnded(IAsyncResult ar)
12/19/2023 4:33:29 AM Information ReadOrCreateConfigurationData
12/19/2023 4:33:29 AM Information ReadOrUpgradeConfigurationData started..
ConfiguratiorI log file error
12/19/2023 12:33:29 ‘IM’ has been executed successfully
12/19/2023 12:33:29
12/19/2023 12:33:29 SqlUpdate failed!
12/19/2023 12:33:29 at VideoOS.Server.Admin.Tasks.SetupDatabaseTask.Install(IDatabaseConnectionInfo databaseConnectionInfoMs, IDatabaseConnectionInfo databaseConnectionInfoIdp, IDatabaseConnectionInfo databaseConnectionInfoIncidentManager, String scriptsPath, String product, String companyName, Version currentDbVersion, Boolean isExternallyManaged, Boolean shouldDeleteDatabases)
I have previously installed XProtect Corporate 2022 R3 on this same server with no issues. I did a clean uninstall of the 2022 version using this guide and subsequently a fresh install of the 2023 R3 version and I encountered this issue. I tried uninstalling the 2023 R3 version (the components still get installed even with this error showing up) using the same guide and doing a fresh install again and I’m met with the same error. My SQL Server Express 2022 is up and running during these installations
Please let me know if you require any more details from my end to identify the issue with this installation. I have attached the 2 related log txt files as well. Your help is greatly appreciated, thank you very much!
