StableFPS connection drops after short playback duration
I have a stablefps video I made by following this guide: https://doc.developer.milestonesys.com/html/gettingstarted/HowToMakeYourOwnStableFPSStream.pdf
The total video duration is about three minutes. However, when I play the video through stablefps, the footage plays for about a minute, then freezes (if you are viewing it in the management client) and loses its connection (if you are viewing it in the smart client - the screen in the smart client goes back.) I’m trying to debug why this happens. In the Recording Server logs ([C:\ProgramData\Milestone\XProtect](file:C:/ProgramData/Milestone/XProtect) Recording Server\Logs\ImageServer.log), I see
“2021-01-26 17:41:36.283+00:00 [ 88] INFO - DevId=c72ebf9f-dc86-4ddc-b979-d800e53c8969 Status: 1=1 2=1 3=1 5=0 (CameraLiveFeedStarted Motion Recording CameraConnectionLost )”
What does this mean? Is it related to the stablefps camera failing? Where else should I look to debug this issue?
If StableFPS is unable to play your video it will fail this way. We suggest you try to change the video maybe recode.
