Streaming sub-frames using Protocol Integration
I am trying to stream historical video from the Image Server using Protocol Integration. From reading the MIPSDK, it appears that I need to use the “Goto” and “Next” requests to retrieve individual frames from the server. In my case I am requesting the raw video feed as opposed to the transcoded jpeg frames.
The problem that I am encountering is that I am getting around 1 frame per second (FPS) instead of the 8 FPS that is configured on the camera in the Management Client. If I stream using the “Live” request, I receive the expected 8 FPS in the native format.
My understanding of the protocol is that after first sending a “Connect” request, I then need to send a single “Goto” request for the first frame. For each subsequent frame I need to send a “Next” request. To build up a video stream I therefore need to send 8 “Next” requests per second for an 8 FPS video stream.
Here are the requests that I am sending to the Image Server
==== Connect ====
<?xml version="1.0" encoding="UTF-8"?>
1
IRRELEVANT
IRRELEVANT
connect
7a5d0046-6268-4612-89a9-2aa16df32c7f
no
id=7a5d0046-6268-4612-89a9-2aa16df32c7f&streamid=44d8dd96-d449-48e3-99db-78925b08c651&connectiontoken=TOKEN#a0307807-6c2d-4a53-8d9e-47e63fb8a3ea#xprotectmaster//ServerConnector#
<privacymask>no</privacymask>
<multipartdata>yes</multipartdata>
<datarestriction>no</datarestriction>
<allframes>yes</allframes>
<keepaspectratio>yes</keepaspectratio>
<allowupsizing>no</allowupsizing>
==== Goto ====
3
goto
1522148021638
no
==== Next ====
4
next
Any advice that you can offer about where I may have gone wrong would be greatly appreciated.
Conversely if you can advise me of a more efficient means of streaming historical video that would also help me to solve my issue.
Kind Regards
When retrieving frames in playback - you retrieve an entire GOP at a time. The default length of a GOP is 1 second. So you need to split the individual frames upon reception.
Please check the GenericByteData header for flags and sizes.
Thanks Anders.
That was exactly the problem and I have found the missing frames.
