The Log server in system monitor shows Node-1 server name after switching the management server cluster node (Xprotect 2019 R3)
When switching management server from node-1 to node-2, the Log server name in system monitor doesn’t changed to node-2 server name, instead it keep showing node-1 server name when click details.
