I am reaching out regarding an issue I encountered when extracting the same video at the same time in both MKV and AVI formats. It appears that only the MKV format does not use the name I set, instead changing it to a specific format.
The original file name I set is “test”, original path is “[C:\Users\user\Desktop\test2](file:C:/Users/user/Desktop/test2)”. When I extract with the same name set for both MKV and AVI, the saved results are as follows:
// 오후 == PM , 오전 == AM
C:\Users\user\Desktop\test2\2025-05-30 오후 2-11-32\Media player format\Camera 1\2025-05-30 오전 (UTC+09_00) 10_51_38.mkv
C:\Users\user\Desktop\test2\2025-05-30 오후 2-11-39\Media player format\Camera 1\test.avi
The code I used is briefly as follows:
string fileName = "test";
IExporter _expoter;
DateTime Start = myDate.StartTime;
DateTime End = myDate.EndTime;
if (selecType == "MKV")
_expoter= new MKVExporter() { Filename = filename + ".mkv"};
_expoter = myPath
else if (selecType == "AVI")
_expoter= new AVIExporter() { Filename = filename + "avi"};
_expoter = myPath
_exporter.Init();
_exporter.CameraList = myList;
bool isStart = _exporter.StartExport(Start,End);
_export.EndExport();
_exporter.Close();
This is very different from the expected result, and it seems that my specified fileName is not being used at all.
I am using the 2023R3 client, and the SDK version is 22.3.0.
- Is it the original behavior of IExporter that a \{current time}\Media player format is created in the specified path?
- Could you please guide me on how to apply the name I set for the MKV file?
- The comment for the “Filename” member of VideoOS.Platform.Data.MKVExporter states ‘Name of the AVI file.’ Could this be related?
Thank you.
