I am trying to login to an Essential+ (C-Code) with disabled encryption through protocol integration. Find the HTTP request below:
POST /ManagementServer/ServerCommandService.svc HTTP/1.1
Host: 192.168.0.57
Content-Type: application/soap+xml
User-Agent: PostmanRuntime/7.20.1
Accept: */*
Cache-Control: no-cache
Postman-Token: cff2cc35-e0fd-4633-b1b3-01aa0f6a9715,1bcda6a7-9dd8-407f-bf21-42d18d75ed9a
Host: 192.168.0.57
Accept-Encoding: gzip, deflate
Content-Length: 1358
Connection: keep-alive
cache-control: no-cache
<?xml version="1.0" encoding="UTF-8"?><SOAP-ENV:Envelope
xmlns:SOAP-ENV=“http://www.w3.org/2003/05/soap-envelope”
xmlns:SOAP-ENC=“http://www.w3.org/2003/05/soap-encoding”
xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance”
xmlns:xsd=“http://www.w3.org/2001/XMLSchema”
xmlns:ns5=“http://schemas.microsoft.com/2003/10/Serialization/Arrays”
xmlns:ns7=“http://schemas.datacontract.org/2004/07/System.Collections”
xmlns:ns4=“http://schemas.microsoft.com/2003/10/Serialization/”
xmlns:ns6=“http://schemas.datacontract.org/2004/07/VideoOS.Common.Proxy.Server”
xmlns:ns1=“http://tempuri.org/”
xmlns:ns3=“http://videoos.net/2/XProtectCSServerCommand”
xmlns:c14n=“http://www.w3.org/2001/10/xml-exc-c14n#”
xmlns:wsu=“http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd”
xmlns:xenc=“http://www.w3.org/2001/04/xmlenc#”
xmlns:wsc=“http://schemas.xmlsoap.org/ws/2005/02/sc”
xmlns:ds=“http://www.w3.org/2000/09/xmldsig#”
xmlns:wsse=“http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd”
xmlns:ns8=“urn:videoos:management:server:servercommandservice”>
</SOAP-ENV:Header>
ns3:instanceIdd3677c4c-dadc-44f9-b5af-ce670a8e5db8</ns3:instanceId>
ns3:currentToken</ns3:currentToken>
</ns3:Login>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
with the response being:
<s:Envelope xmlns:s=“http://www.w3.org/2003/05/soap-envelope” xmlns:a=“http://www.w3.org/2005/08/addressing”>
<s:Header>
<a:Action s:mustUnderstand="1">[http://www.w3.org/2005/08/addressing/soap/fault</a:Action>](http://www.w3.org/2005/08/addressing/soap/fault%3C/a:Action%3E)
</s:Header>
<s:Body>
<s:Fault>
<s:Code>
<s:Value>s:Sender</s:Value>
<s:Subcode>
<s:Value xmlns:a="[http://schemas.xmlsoap.org/ws/2005/02/sc](http://schemas.xmlsoap.org/ws/2005/02/sc)">a:BadContextToken</s:Value>
</s:Subcode>
</s:Code>
<s:Reason>
<s:Text xml:lang="en-US">The security context token is expired or is not valid. The message was not processed.</s:Text>
</s:Reason>
</s:Fault>
</s:Body>
</s:Envelope>
I used Postman on Ubuntu 16.04 LTS to send the request.
any clue?
