Int he attached screenshot, there is a popop on top of a plugin using the ImageViewerWpfControl.
We are using SDK 2021. Assuming this has something to do with the multiple playback tracks available in 2023R2? Is there a way to get the timeline to display in a ImageViewerWpfControl without updating the SDK version?
Does the timeline appear in the WPF sample for 2023R2?
Is there going to be a way to select which track(s) are displayed?
The Independent Playback timeline is always only one line. I believe you are comparing the main timeline control with that of the independent playback. Independent playback you can try from the Smart Client camera view toolbar or from the Smart Client Independent Playback plugin sample.
