Hi all,
I am writing a plugin and one of the requirements is that I need to turn on/off Independent Playback mode for camera views in SmartClient “LIVE” workspace. There is a button on camera view toolbar, but I need to find out how to do it programmatically. Lets say I have a button in my plugin, and when I press it, it has to turn on/off Independent Playback mode for a certain camera.
Thanks in advance.
If you have developed your own view item plugin then you can do this. The Smart Client Independent Playback plugin sample shows this.
http://doc.developer.milestonesys.com/html/index.html?base=samples/scindependentplayback.html&tree=tree_1.html
If you want to take control of regular camera view items it is not possible to turn on/off independent playback.
From what I read it is probably the latter you would prefer to do, and then it is not possible. I will see to it that it gets mentioned as a possible future enhancement for the MIP SDK in the wish-list of the Milestone SDK team.
The enhancement mentioned was prioritized and has now been developed, it is planned to release with the 2021 R1 version.
