This issue is related to old CASE ID : MSC1308790 .
1.> As you suggested i tried to use the " Config API Client" sample and try to update the LPR MatchList. Unabel to update the License plate.
In teh Milestone sample app: When tried to add LPR plate number says error in dialog “Add or Edit data for Registration number dialog” list of registration numbers are not displated and grayed out.
Error Disply : Propery not found for : Registrationnumbers
Exact error and flow pelase view the attched image file.
2.> From the " Config API Client" the exact API unknown when referring to this sample. As GUI is embedded gui from another DLL unable to get exact API to use. I need need to call Milestone MIP API to add LPR plate number from our custom video app. Please tell the exact API to call to list of license plates , add , remove license plate numbers to LPR match list / blacklist.
Example: In the alarm viewer sample , APIs are very clear to subscribe and get alarms , same way i need APIs for the list of license plates , add , remove license plate numbers to LPR match list / blacklist.
Please help to clarify asap, as urgent one for us.
Regards,
Vivek
