Hi, using your C# projects in particular I am using the MediaLiveViewer and VideoViewer solution. I’m having problems receiving Live and Playback frames, in particular the exception with “unable to connect to toolkit” is thrown in the eventagrs. However, by trying to use these applications inside the machine where the server is installed, the frames are received correctly. Reading in old posts I saw that problem could be communication with some ports, but by telnetting with them I don’t encounter any problems. I tried disabling both firewalls but to no avail. Can you tell me a solution? Below are the details of the environment:
MIP Server: 2023 R1 1a
OS not working (wo MIP server): Windows 11
Working OS (w MIP server): Windows 10
If you need more details, don’t hesitate to ask
Thank you very much for helping
