Hello I was trying to download SDK from nuGet, but all was able to locate was x64 one. I have been getting ‘System.TypeInitializationException’ milestone and some more error while trying to add the dlls into resource
When Milestone discontinued the MIP SDK installer after 202R1 version of the MIP SDK, it also meant that there is no longer a 32 bit version of the MIPSDK
You are still able to download the old installer. Milestone recommends that you move to using 64 bit
http://download.milestonesys.com/MIPSDK/MIPSDK_Redist_Installer_x86_2022R1.msi
Thank you. I will install and grab the files to in build
I must suspect that you have a mix of new and old dlls or references. Try to make absolutely sure that you have removed everything before referencing and copying the new.
Maybe you need this installer too as it will give you the old samples and old documentation. If you have both 32 and 64 bit make sure then to use the right bin folder when you copy dlls so that you get the right dll and not a mix.
https://download.milestonesys.com/MIPSDK/MIPSDK_Installer_2022R1.msi
