I am unable to use some bigger analytic events to generate alarms. Following message is printed to logs:
019-07-31 12:00:00 AM UTC+03:00 Error XPathSqlConnection Error importing XML: Error executing post SQL command. InnerException: String or binary data would be truncated.
Skipping import of root node: . EventHeader ID: 152f2a9a-fea4-46bb-aee6-45c11d0e8d08
2019-07-31 12:00:00 AM UTC+03:00 Error Alarm cache Failed to add Alarm. Exception: Unable to insert alarm in database.
Exception details:
System.Exception: Unable to insert alarm in database.
at VideoOS.Event.Server.DB.AlarmDbHandlers.AlarmHandler.Write(Alarm alarm, BaseEvent baseEvent, XPathSqlConnection xPathSqlConnection)
at VideoOS.Event.Server.Alarm.AlarmActionItems.AddAlarmActionItem.Execute()
at VideoOS.Event.Server.Alarm.AlarmCache.Write(IEnumerable`1 items)
at VideoOS.Event.Server.Alarm.Cache`1.AddWorkerThread()
Can anything be done to increase size limit?
