Upgrading VideoOS.Plateform.SDK nuget Bug
For your info.
Upgrading / installing MilestonSystems.VideoOS.Plateform.SDK 25.2.1 from visual studio nuget getting following error.
It work fine for all previous version, for now using 25.1.3
System.IO.DirectoryNotFoundException: Could not find a part of the path '\packages\Microsoft.Extensions.DependencyInjection.Abstractions.9.0.0\buildTransitive/netcoreapp2.0/Microsoft.Extensions.DependencyInjection.Abstractions.targets'.
   at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
   at System.IO.File.InternalCopy(String sourceFileName, String destFileName, Boolean overwrite, Boolean checkHost)
   at NuGet.Packaging.PackageFileExtractor.ExtractPackageFile(String source, String target, Stream stream)
   at NuGet.Packaging.PackageFolderReader.CopyFiles(String destination, IEnumerable`1 packageFiles, ExtractPackageFileDelegate extractFile, ILogger logger, CancellationToken token)
   at NuGet.Packaging.PackageReaderBase.CopyFilesAsync(String destination, IEnumerable`1 packageFiles, ExtractPackageFileDelegate extractFile, ILogger logger, CancellationToken cancellationToken)
   at NuGet.Packaging.PackageExtractor.<ExtractPackageAsync>d__1.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   at NuGet.ProjectManagement.FolderNuGetProject.<>c__DisplayClass13_0.<<InstallPackageAsync>b__0>d.MoveNext()
   at NuGet.Common.ConcurrencyUtilities.<ExecuteWithFileLockedAsync>d__11`1.MoveNext()
   at NuGet.ProjectManagement.MSBuildNuGetProject.<InstallPackageAsync>d__36.MoveNext()
   at NuGet.PackageManagement.NuGetPackageManager.<ExecuteInstallAsync>d__101.MoveNext()
   at NuGet.PackageManagement.NuGetPackageManager.<ExecuteNuGetProjectActionsAsync>d__87.MoveNext()
   at NuGet.PackageManagement.NuGetPackageManager.<ExecuteNuGetProjectActionsAsync>d__86.MoveNext()
   at NuGet.PackageManagement.NuGetPackageManager.<ExecuteNuGetProjectActionsAsync>d__85.MoveNext()
   at NuGet.PackageManagement.VisualStudio.NuGetProjectManagerService.<>c__DisplayClass20_0.<<ExecuteActionsAsync>b__0>d.MoveNext()
   at NuGet.PackageManagement.VisualStudio.NuGetProjectManagerService.<CatchAndRethrowExceptionAsync>d__32.MoveNext()
Time Elapsed: 00:00:05.0062033
I didn’t have an issue when updating the MilestonePSTools project to 25.2.1. Do you need to do a package restore? I have a “-restore” in my msbuild command so maybe that’s why I didn’t see the same problem?
