Dear Nikolay-san,
Thank you for your response.
My partner has some additional questions.
Please provide your answers.
Q1: Do you plan to make changes to support “ports above the upper limit of 32,767” in order to accommodate the specified port range? Alternatively, would it be possible to handle this on a case-by-case basis?
Q2: Does “Software” in your response refer to “ImageViewerWpfControl”?
Q3: Is this limitation specific to “ImageViewerWpfControl”?
Or does it stem from common internal reception and playback processing?
Q4: Please specify the scope of this limitation.
・Does it apply only to multicast receive ports?
・Does it apply to UDP ports in general?
・Does it extend to related port processing such as RTP/RTCP?
・Does it apply only to the display control, or to the entire reception process?
Q5: Is this behavior by design, or is it a known issue?
Q6: Please let us know if there are any plans to fix this, or if there is information regarding affected versions or versions where it has already been fixed.
Q7: We have built our application based on “ImageViewerWpfControl” and would like to avoid major rework.
Please let us know if there are any Milestone-recommended workarounds or alternative approaches that can address this without significantly changing our existing configuration.
Best regards,
NVS Technical Support
