Is there a known issue with using /api/rest/v1/alarms and specifying a tag value. I am using XProtect 2023 R3 and find that the tag value is not assigned to the generated alarm. Also, when getting alarms the tag element is not included in the response.
I see that the tag element is defined in the https://doc.developer.milestonesys.com/mipvmsapi/api/alarms-rest/v1/#tag/Alarms/operation/Alarms_Post endpoint.
