Various error when trying to stream live camera views from the MIPS SDK
Our software is talking to the MIPS SDK to connect to, get a list of cameras, and then getting a streaming control to view in our product.
This works well up to a point, but after a certain number of cameras is reached, the whole process simply disappears with a crash. Here are some Windows Event Logs for various files related to the crash. (Its one of about 4 to 6 different files every time) Our program is the Velocity.Video.Real.exe in these examples
Error type 1
Faulting application name: Velocity.Video.Real.exe, version: 1.1.9.5, time stamp: 0x64c1ae52
Faulting module name: ntdll.dll, version: 10.0.19041.3155, time stamp: 0x2daa62a8
Exception code: 0xc0000374
Fault offset: 0x000e6d63
Faulting process id: 0x3498
Faulting application start time: 0x01d9c3f70733616c
Faulting application path: [C:\Program](file:C:/Program) Files (x86)\Identiv\Velocity\Velocity.Video.Real.exe
Faulting module path: [C:\WINDOWS\SYSTEM32\ntdll.dll](file:C:/WINDOWS/SYSTEM32/ntdll.dll)
Report Id: be446426-e61f-4319-a47e-66ebfc82442d
Faulting package full name:
Faulting package-relative application ID:
Error type 2
Faulting module name: CoreMessaging.dll, version: 10.0.19041.3208, time stamp: 0x859f2afe
Exception code: 0xc00001ad
Fault offset: 0x0001387c
Faulting process id: 0x3724
Faulting application start time: 0x01d9c3f6bbb64cae
Faulting module path: [C:\WINDOWS\System32\CoreMessaging.dll](file:C:/WINDOWS/System32/CoreMessaging.dll)
Report Id: f0277205-5dc0-4ac9-a0e9-4a2f2dbcbe4f
Error type 3
Faulting module name: KERNELBASE.dll, version: 10.0.19041.3208, time stamp: 0xbc1cd7c0
Exception code: 0x80000003
Fault offset: 0x00183952
Faulting process id: 0x2fa4
Faulting application start time: 0x01d9c3f6bfbe7a0d
Faulting module path: [C:\WINDOWS\System32\KERNELBASE.dll](file:C:/WINDOWS/System32/KERNELBASE.dll)
Report Id: 3154e16a-b490-4fa5-b5aa-1761d8f73161
Error type 4
Faulting module name: d3d9.dll, version: 10.0.19041.2788, time stamp: 0x69fef241
Exception code: 0xc0000005
Fault offset: 0x000e4d8b
Faulting process id: 0x78d8
Faulting application start time: 0x01d9c3e065e43fc7
Faulting module path: [C:\WINDOWS\SYSTEM32\d3d9.dll](file:C:/WINDOWS/SYSTEM32/d3d9.dll)
Report Id: 3a00e7fe-facb-447c-a70e-a0a80887bedb
Also, from time to time, the sdk will cough up some errors:
Note: I can reproduce this in our software always. But I also wrote a simplified version of it using the sample code taken from the ImageViewerClient sample. This program is able to stream over 100 cameras without issue, but our software crashes when reach between 9 and 16.
Does anyone have any insight as to what could cause this?
For further investigation, let me ask you several questions.
1. When you run Smart Client (without any plugins), do you see the same issue?
2. Can you please tell us which version and edition of VMS you are using?
3. Please verify that you are using the newest dlls from Nuget packages (https://www.nuget.org/packages?q=milestone+systems ). If you have not used the newest, get the newest and try it out once more and see if you will get the same issue? Also, please use the newest sample too. https://github.com/milestonesys
Ok some more information. I found that this is due to the way our software is architected. We have a WPF exe (Velocity.Video.Real.exe) that is a background process. It is used to manage our camera view group and will show Video Explorer windows which are responsible for streaming the cameras on them.
The Video Explorer is also a WPF exe, (Velocity.Video.VideoExplorer.exe). Since this is a UI application, it is called on a new System.Threading.Thread using the System.Windows.Threading.Dispatcher so it can be shown to the user.
This works up to a point. Each View Group can show up to 16 cameras feeds at once. On my system, once I reach streaming 9 to 12 cameras, the Video.Explorer will crash the whole process which includes the Video.Real.
I have substituted our Video.Explorer with a sample exe I used based off your ImageViewerClient sample, which hosts a stream of 16 camera feeds. If I run this sample by itself, it can load 7 instances of itself with no problems. If I have the Video.Real launch it using the method above, it will crash on the first instance while trying to stream the initial 16 cameras.
I have created the sample using the latest nuget packages. The sample is very simple and does what in needs to do, the problem seems to be the WAY it is launched.
Any ideas on why the Dispatcher on a new thread would cause this crashing issue?
For further investigation, can you please give us a small sample that can reproduce the issue?
The problem turned out to be we had an unsupported video card: AMD
This was solved by using this sdk setting:
EnvironmentManager.Instance.EnvironmentOptions[“HardwareDecodingMode”] = “Off”;
