video initialization error can not connect to the source
good afternoon!!
I installed xprotect professional 8
windows server 2008 r2
the problem in the following:
when exporting the episode, after “information from the server”
with shows, click “Export” button
there is an error “failed to initialize the video stream can not connect to the source”
here in the forum I found a description of this type of problem
1, this chunk of time there on the server
2 I am an administrator on the server
3 in the name of the cameras are no special characters
in what could be another problem?
One idea: Is the PC out of sync (on time) with the server? Is the camera out of sync?
I assume you use the Smart Client and export in Milestone format?
If you move the start of the export forward one frame, does it maek a difference?
everything happens on the same computer.
I exported to avi
Is the camera time in sync with the system time of the PC?
Does it fail no matter the interval of export?
