Recorded sequence on the timeline are not showing on 2023R2, when i added in my plugin. if i use the same plugin on 2022R3, it shows the red recorded sequence.
I have also notices that if i switches the different tabs on the smart client, sometime it start to show the sequence.
Following is the Timeline for 2022R3same code for 2023R2
Part of the initialization
_imagePlaybackViewerControl = new PlaybackWpfUserControl();
I think there is some bug in the Smart Client 2023R2 with the timeline, on multiple tab switching between Live and playback sometime it start to show the recording red bar sequence and it work fine on previous releases.
Milestone Development have developed a fix which will be in Smart Client 2023R3 which is released later this year. I wonder if this is critical for you, should I ask whether a hot-fix for Smart Client 2023R2 can be built?
