VideoOS.Platform.SDK.Export.Environment.Initialize() Throws 'System.IO.FileNotFoundException'
Help Please,
Though I have VideoOS.Platform.SDK.Export for 32-bit and added in reference, I am getting ‘System.IO.FileNotFoundException’ for this
I am using 21.1.4312.1 SDK (Since I could not find latest SDK for 32-bit)
Please double-check that the dlls are in the folder where you are executing, and that you do not have a mix of dlls from different versions.
If you look in the old documentation, under Component Integration - .NET Library initialization, there might be some instructions of use.
You might have the documentation locally from an installer but otherwise look at -
https://doc.developer.milestonesys.com/html-2022r1/
