The following code illustrate my problem:
private void CreateView()
var ms = new ManagementServer(EnvironmentManager.Instance.MasterSite);
var destination = ms.ViewGroupFolder.ViewGroups.First(v => v.DisplayName == "Test").ViewGroupFolder.ViewGroups.First(v => v.DisplayName == "Views");
var layoutGroup = ms.LayoutGroupFolder.LayoutGroups.First(l => l.DisplayName == "4:3");
var layout = layoutGroup.LayoutFolder.Layouts.First(l => l.DisplayName == "3 x 3");
var xml = System.Xml.Linq.XElement.Parse(layout.DefinitionXml);
var layoutType = xml.Attribute("ViewLayoutType").Value;
var layoutCustomId = xml.Attribute("Id").Value;
var layoutViewItems = xml.Element("ViewItems").ToString();
var layoutIcon = xml.Element("ViewLayoutIcon").Value;
// ------ 1 START ------
// NOT WORKING
//var task = destination.ViewFolder.AddView("Demo", "", layoutType, layoutCustomId, layoutIcon, layoutViewItems);
//while (task.State != StateEnum.Error && task.State != StateEnum.Success)
// System.Threading.Thread.Sleep(10);
// task.UpdateState();
//var view = new Task(EnvironmentManager.Instance.MasterSite.ServerId, task.Path);
// ------ 1 END ------
// ------ 2 START ------
// WORKING but deprecated
var task = destination.ViewFolder.AddView(layoutViewItems);
task.SetProperty("Name", "Demo");
task.ExecuteDefault();
// ------ 2 END ------
var items = view.ViewItemChildItems.ToList();
if (items.Count != 9)
throw new Exception("Error");
Basically, only the deprecated version of ViewFolder::AddView works.
What happens is that the number of ViewItemChildItems when using the first code block is always 2, and when using the deprecated version then it’s correctly set to 9.
In both cases the views are created it’s just the number of ViewItemChildItems that is not correct.
