Following error we get in Xprotect Event Server Log and Event server service stop.
Failed to update action from provider = Bataction
BatAction is a plugin sample that should not have any influence on an Access plugin. Please try to disable or remove all plugins except your own.
Does all work well? Do you see an error on your plugin?
