We are tring to understand if there is a way to limit FPS/image quality based on Bandwidth.
Customer requires adaptive streaming to mobile devices, we want to understand how this can be configured from the mobile server side.
i.e. when bandwidth drops below threshhold reduce FPS to half
or reduce resolution from 4k to 1080p.
or both?
is there any way we can manage this? what s the level of detail this can be managed on the milestone xprotect side?
Thank you.
Benny.
There are some configuration on the performance tab of Mobile Server configuration plugin in Management Client. You can refer to this document for more information:
https://doc.milestonesys.com/latest/en-US/standard_features/sf_mobile/mobc_adaptivestreamingexplained.htm?tocpath=XProtect%20Mobile%20client%7CConfiguration%7C_____14
and also :
https://doc.milestonesys.com/latest/en-US/standard_features/sf_mobile/mobs_mobileserversettings.htm?tocpath=Add-ons%7CXProtect%20Mobile%20server%7CConfiguration%7C_____1#Performancetab
Kind Regards,
Svetlana
