Our customer has set up XProtect Corporate 2020R2. Our component with SDK2020R3 included connects and streams from their VMS just fine. For a certain reason we tried to roll back SDK to 2018R3 in our component. It works the same in our dev setup but fails to stream in the customer setup. They get a “Connection to camera failed. Retrying…” message after successful basic authentication. Could You provide a full list of software requirements for SDK2018R3 to connect correctly to XProtect 2020R2 an stream? We are only aware of Microsoft .NET 4.7 or higher.
The customer’s VMS:
- VMS XProtect Corporate 2020R2
The customer’s client machine:
- Windows 10
- .NET 4.7.or higher
- NVIDIA Quadro P2200
- NVIDIA drivers 400 or higher but installed by Windows Update
