While trying to push events using webhook, the time gotten and actual alarm time is very different, any idea what should be done or what went wrong? Many thanks!
Can you please verify that the Milestone servers and cameras are synchronized? This question might be similar and maybe helpful for you to see -
Hi Rie Kito,
Milestone server and cameras are synchronized. So I dont really know what else could be causing the difference in time zone, normal alarm shows correct timestamp, it only changes when it’s being pushed through webhook
How much time is the difference between the event and the webhook sent date? Regarding the webhooks, they are triggered after an event has happened, so I would expect that an event happens, it triggers a rule and then it is sent in the webhooks. There will always be a lag. There might be conditions in the rule that make this even slower.
