I am currently working on a custom web client using Angular, where we utilize WebRTC to stream video from Milestone XProtect. While standard forward playback for recorded video works without issues, we have a strict requirement to implement backward/reverse playback and I would like to ask you few questions:
Does the Milestone WebRTC implementation natively support backward playback for recorded video?
If it is supported, how can I control the playback direction (and potentially speed) via the WebRTC signaling channel or the relevant API?
If backward playback is not currently supported via WebRTC, what is the recommended best practice to achieve this in a web client?
