What is the cause of error 24 when trying to use VideoPush to playback a recorded video: "FeatureIsDisabled 24 Complete Response"
The following error 24 occurs when trying to playback a recorded video (using the XPMobileSDK library) using XPMobileSDK.interfaces.VideoPushConnection
ERROR returned:
XMLHttpRequest {readyState: 4, timeout: 0, withCredentials: false, upload: XMLHttpRequestUpload, onreadystatechange: ƒ, …}
XPMobileSDK.library.js:2580 Response error FeatureIsDisabled 24 Complete response: <?xml version="1.0" encoding="utf-8"?>189f970c-dea0-4e1f-843e-b8e98a420b2eResponseRequestStreamError24
XPMobileSDK.library.js:1772 stream— ./src/ducks/library/XPMobileSDK.library.js.XPMobileSDK.library.ConnectionRequest {options: {…}, response: ./…K.l…y.js.X…K.l…y.ConnectionResponse, params: {…}, cancel: ƒ}
XPMobileSDK.library.js:2282 Error starting stream for camera undefined
XPMobileSDK.library.js:3115 requestPushStreamFailed
CODE:
* @class VideoPushConnection
* @type {Object}
* @property {Function} open - Opens the video push connection
* @property {Function} close - Closes the video push connection
* @property {Function} send - Sends video frame to server
* @property {Function} destroy - Class destructor
* @property {Function} isOpen - Checks if the connection is open
* @property {Function} getMediaStream - Retrieves a media stream
XPMobileSDK.interfaces.VideoPushConnection = {
* Opens the video push connection
* @method open
open: function (successCallback, errorCallback) { },
* Closes the video push connection
* @method close
close: function () { },
* Sends video frame to server
* @method send
send: function (base64EncodedImage) { },
* Class destructor
* @method destroy
destroy: function () { },
* Checks if the connection is open
* @method isOpen
* @return Boolean - Returns the stream object if the connection is opened
isOpen: function () { return Boolean(); },
* Retrieves a media stream
* @method getMediaStream
getMediaStream: function () { return new MediaStream(); }
Hello Daniel,
Can you give us some more details what you are trying to do. It will be very helpful if you share with us the request you send to the Mobile server. What I am guessing is that you are trying to do a video push from a device to the Mobile server. In order to do so you need to enable it in the VMS. Here is a link to the details how to enable the video push : https://www.milestonesys.com/globalassets/techcomm/ltsb/provms/english-united-states/index.htm?toc.htm?7289.htm
Teodor, Thank you.
We have Milestone Management Server 2017 R1 at the moment.
This link that you provided was helpful: https://www.milestonesys.com/globalassets/techcomm/ltsb/provms/english-united-states/index.htm?toc.htm?7289.htm
We have on older version (2017 R1), and we apparently are missing some things mentioned in the documentation.
