What port numbers do we need to open for accessing to the Milestone VMS over the SoAP, please?
We are developing solution for cloud based video streaming from the on-premise Milestone.
As our servers use the Linux based OS, we assume only SoAP can be used for accessing Milestone API. When checking the documentation, it looks many ports have to be open on the firewall in order to accessing the the Milestone over the SoAP and it looks bit complicated. Following is the link to protocol integration.
https://doc.developer.milestonesys.com/html/index.html
This KB article might be helpful for you.
https://developer.milestonesys.com/s/article/TCPIP-ports-used-in-XProtect-Advanced-VMS-products
Dear Rie,
Thank you very much. Can you please tell exact port numbers used for the SoAP?
Hi. There are many soap protocols and we could not say the default port numbers without knowing more.
In any event the user can change the ports to be used away from the default. Please see “Services and how to find addresses and ports” here: https://doc.developer.milestonesys.com/html/index.html?base=gettingstarted/intro_soap_protocols.html&tree=tree_3.html
