I have found that there was a thread with same issue that occurred in 2018 (https://developer.milestonesys.com/s/question/0D50O00004PlxELSAZ/working-with-multiple-imageviewerwpfcontrols-causes-application-to-hang-in-some-scenarios ), but there is no solution there.
We are facing the same issue.
When video slots got disposed - there is a 60 second ‘hang’ that blocks our application.
Is there a solution for this issue? or any workaround?
I could not find one.
Regards.
Rik
August 3, 2023, 1:14pm
2
I checked the old support case in our system. The customer in the case was using x86, and they installed newer (2018 R2) binaries as a solution. And then the issue was gone and solved the issue.
2018R2 is very old for now so I don’t think the solution above fits for your case.
So can you please tell me -
Which version of VMS you use?
Please verify that you are using the newest SDK from Nuget https://www.nuget.org/packages?q=milestone+systems
If you are using samples, please also use the newest ones from here - https://github.com/milestonesys
Thanks for a reply @Rie Kiuchi (Milestone Systems)
We are using 2022.R3 (I believe the integration was developed for 2019.R2 and then was upgraded specifically for 2022.R3)
It has been working pretty good and there were no issues.
I think that is the functionality that was not used by us earlier so nobody ever noticed this before.
I will check the newest 2023 SDK and get feedback if it solved our issue or not.
