When I try to call login method on the server, the exception is:System.ServiceModel.EndpointNotFoundException. Looks like the endpoint is not listening.My code and the XProtect Professional server is on the same pc, and firewall is disabled.
System.ServiceModel.EndpointNotFoundException: ‘Nessun endpoint in ascolto su https://192.168.0.39/ManagementServer/ServerCommandService.svc in grado di accettare il messaggio. Ciò è spesso causato da un’azione SOAP o un indirizzo non corretto. Per ulteriori dettagli, vedere InnerException, se presente.’
Please run the TCP Video Viewer sample sample unmodified; do you get the same error?
https://doc.developer.milestonesys.com/html/index.html?base=samples/tcpviewer_sample.html&tree=tree_search.html?search=tcp+video+viewer
What version is the MIP SDK? What version is the XProtect Professional?
