When installing MIP Plugin at Xprotect Professional with axis M1125, to receive metadata of perimeter defender, there is a error. what Ip/port/user/pass do i put in the filds?Tanks
Is this a MIP plugin you have developed? What does your MIP plugin do?
Has I described, the MIP plugin is developed by Axis.
The Plugin sends metadata to Milestone.
Very well. I do not expect Axis support to monitor this forum. Would be nice though :slight_smile:
Please try to ask Axis. Unfortunately I have no knowledge or experience with the mentioned plugin.
“It can be used with both XProtect Professional/Enterprise (note: up to v.2.0.0 and no metadata support” …
I suggest you have a look at our article about this integration here:
https://developer.milestonesys.com/s/article/Integration-with-Axis-Perimeter-Defender?t=1521534170661
Ok ,
Tanks
Joel
