I’ve had a working Access Control plugin for some time, that is in production in many different environments. I just had a new customer report an issue with the integration when adding a new Access Control system via the Management Client. It errors out at the end of the wizard (where it would normally tell you how many of each element type have been discovered) and says “Invalid Configuration Received”. In the MIP log, it states:
Error MIPPluginTrace Error during call to S2Access.Plugin.S2AccessSystem.Close(). Exception message: Close
I examined my code, and sure enough found that my ACSystem.Close() method was not implemented:
public override void Close()
throw new NotImplementedException("Close");
Obviously I can take that throw statement away, but I’m trying to figure out what changed. We’ve used this plugin in so many places without encountering this, so the ACSystem.Close() method must rarely be called, hence my question:
When exactly is that method called (besides when the Event Server is stopped)?
