When using federation mode is it possible to receive Items with the same FQID.ObjectId from different servers?
The integration that is currently implementing requires federation mode support. Using sample I was able to get all servers and corresponding sensors. Now I am wondering if there is a possibility that I will receive duplicate error as I expect FQID.ObjectId to be unique?
If there’s a duplicate ID in a child site, I know smart client will tell you this and not allow you to login due to the “broken” config. I’m not sure if this error is a part of the SDK or if it’s an added check done in the smart client itself.
That said, the odds of a GUID collision are astronomical. The odds are so low, that the only reasonable way it could happen​ is if someone intentionally cloned the configuration.
