I am sorry in my poor English.
Using VideoViewer in ComponentSamples of MIP SDK,
If you select playback mode with the operation below, the CPU will increase and the playback operation will be impossible.
1. Start Video Viewer.exe.
2. Enter your account and login.
3. Select an arbitrary camera.
· Live is displayed.
4. Click the “Current mode: Live” button.
· While playback mode is set, images are not displayed.
CPU is increased.
[Xprotect version]
Milestone Xprotect Professional 2016 R2 10.1a (1025)
[Operating environment]
* PC1
Maker: Hewlette-Packard Companey
Type: s 5 - 1270 jp
OS: Windows 7 Professional SP 1 (64 bit)
CPU: i7-3770 CPU @ 3.40 GHz 3.40 GHz
Memory: 8.0 GB
* PC 2
Maker: ASUS
Type: X555L
OS: Windows 10 Home (64 bit)
CPU: i7 - 4510 U @ 2.00 GHz 2.60 GHz
Memory: 8.0 GB
[Remarks]
An event occurs in both the local environment and the network environment of the Recording Server.
An event occurs for both camera codec MJPEG, H.264.
Live will be displayed without problems.
Even if you disable security software an event will occur.
We verify six PCs, only PC1 and PC2 above will be generated.
We do not verify whether the same type as PC1, PC2 always occurs.
