These files are no longer there since 2018.
2018 releases were the last MIP SDK releases to include the following components: ImageViewer, AudioPlayer, EngineManager ActiveXs and the “UseActiveX” environment option.
With MIP SDK 2019 R1 these components will be officially discontinued and will no longer be included in the MIP SDK
If you are getting an error when using the newest MIP SDK and the sample you mention I must suspect some form of setup error that I have not experienced yet when doing support, so if this is the case please elaborate on what you are doing and what you are experiencing
