Where is the image stored from analytic event trigger?
We have an analytic event setup that sends over the captured face from our facial recognition software. We want to use the cropped image that is sent over but are unable to locate where it gets stored.
It is stored in the SQL Server database which hold configuration data and event server data including data on analytics events and snapshots.
The Milestone SQL database is not documented and using it directly is not supported.
I recommend that you read the analytics event and snapshot list using MIP SDK methods.
The Alarm and Event Viewer sample shows you how to read the analytics event or alarm, this sample can be extended to use the SnapshotList.
https://doc.developer.milestonesys.com/html/index.html?base=samples/alarmviewer_sample.html&tree=tree_2.html
https://doc.developer.milestonesys.com/html/index.html?base=miphelp/class_video_o_s_1_1_platform_1_1_data_1_1_analytics_event.html&tree=tree_search.html?search=analyticsevent
