Hi there,
We are developing an access control plugin and we have been told that firing an event categorized as alarm through the plugin is not the preferred way to synchronize alarms, that there is another SDK we should use.
I have been going through the documentation (and the SDK’s assemblies) and so far, I have only been able to find 2 ways to sync the alarms:
Firing an event categorized as an alarm to create it, and then use the IACAlarmRepository instance to keep the alarm synchronized between both systems (just as we have implemented it).
Create the alarm using the AlarmServiceToken webservice
Wouldn’t (2) still require subscribing to IACAlarmRepoistory’s AlarmChanged event?
Is there any other option we aren’t aware of?
Which would be the “best” way of synchronizing the alarms?
Thank you for your patience and time.
