Code
(Vega)
1
We are not getting any window state change handler event for a floating or secondary window, except for the primary window.
We are only getting the window state change for primary, but not for others.
using : XProtect Corporate 2025 R3 Update 2
Thanks,
Vega
Can I reproduce this issue using the unmodified Message Tester plugin sample?
Please give me some ideas how I might reproduce your observation. Preferably I can use the sample but in any case let me know how to best reproduce.
Code
(Vega)
3
Yes.
messagetester on primary windows gives window state change, but not in floating window.
minimize and restore the floating window with message tester in any view.
I can reproduce this now.
Do you have any indication whether this was recently introduced, or if it has also been present in earlier XProtect versions?
Code
(Vega)
5
We are trying this in the new project, had not used in older projects.
I made a bug report with Milestone Development, I will make an update here when I have feedback.
Milestone Development developed a fix, the fix will be in Smart Client 2026R1 update 1 soon to be released.
