Wizard Like For Demo Access Control
Hello everybody,
I want to create a plugin like the Demo Access Control Plugin.Instead of creating doors, I want to create intercom keypad : When you create a element in The Management Client, the software shows you several Windows as a Wizard with Next button. I want also drag and drop camera to associate my keypad with a camera . All these features are integrated in the Access Control Module.
If I want to do the same in my plugin, what samples can I use or have you specific documentations about this ?
You cannot use the Demo Access Control sample as inspiration for your plugin, because the sample uses an Access Control framework and can only be used for integrating Access Control and will require special licensing etc.
Instead, we would like to recommend exploring the Sensor Monitor sample, it might be a place to start for you even if it might not have everything you need -
https://doc.developer.milestonesys.com/html/index.html?base=samples/sensormonitor_sample.html&tree=tree_search.html?search=sensor+monitor
