Wrong Site Item loaded in MultiSite application
I have a strange issue where the same Site Item is loaded if I connect to a second Milestone system.
I used the MultiSiteStatusViewer (MIP SDK 2021 R2) application to confirm the issue.
I have 2 pcs on the same network. Each one with its own Milestone 2021 instance.
I run the MultiSiteStatusViewer on PC1 and connect to PC1’s Milestone. The site connects and the SiteItem is loaded correctly. Then I try to add PC2, but the SiteItem that is returned by the
Item siteItem = VideoOS.Platform.SDK.Environment.LoadSiteItem(secureOnlyCheckBox.Checked, uri, _credentialCache);”
call returns PC1’s SiteItem.
If I then close the application and load PC2 first, then PC2 connects to Milestone and the SiteItem is loaded correctly. If I then try to add PC1, then PC2’s SiteItem is returned again for PC2’s ip.
It seems that the SDK environment is somehow keeping the first site it loads in memory, and doesn’t clear it? I tried to remove the server first and then loading the site item without success. Only when I close the application and open it again, I can load a new site item. (but always only one).
I attached a video that demonstrates this clearly.
Please notice the uri and PC names in the video.
PC1: 192.168.1.15 (JDM-DELL)
PC2: 192.168.1.2 (JDM-PC)
This was reported to Milestone recently. Milestone Development is actually working on a fix for this issue. I will put more information here when a solution is found.
Milestone Development have developed a fix. Please download and use the MIP SDK installer found here: https://supportcommunity.milestonesys.com/s/article/XProtect-2021-R2-cumulative-patch-installers?language=en_US
Please note that the fix is an installer installing new dlls on your PC. If you have used NuGet you must turn off the reference to the NuGet and instead reference the dlls in the MIP SDK Bin folder directly.
The fix will ensure that the Multi-Site Viewer and Multi-Site Status Viewer samples and MIP SDK based applications using the same methods as the samples for logging into and using multiple sites will work.
We would appreciate if you will post an update whether the fixed version works as expected for you.
We also ran into this bug and it was biting us very hard. Glad to see that it has already been fixed.
