XPCO version 5.0c - Can't Connect to Server after upgrading MIP sdk to latest 5.1e
Hi, I am using Milestone Xprotect Corporate 5.0c
With MIP sdk sp3 (previous released version (5.1.0.0)) I was able to regularly connect to my system and use your .net componets examples.
Today I upgraded to MIP sdk 5.1e (latest version available) and I can’t connect anymore (I have tried different examples)!
“Failed to connect to server ()”
In debug (exception says 'unable to connect to endpoint) I have seen that Login(uri) tries to connect to
…\ManagementServer/ServerCommandService.svc
which doesn’t exist!!!
Is Corporate 5.0c still supported by MIP sdk?
How can i tell to Login function that my system is 5.0c??
Hi, you should check the product-lifecycle. The “latest version” of the SDK is not tested or designed to work with terminated products.
I reproduced the issue, I will raise it with the Milestone Development.
It is true that XProtect Corporate 5.0 is discontinued, however the MIP SDK tries to maintain backwards compatibility..
https://force.milestonesys.com/support/articles/en_US/FAQ/About-MIP-SDK-compatibility-with-XProtect-product-versions
If you have this issue with MIP SDK 5.1e please use this MIP SDK 5.1f instead -
www.milestonesys.com/download/MIPSDK/MIPSDK_Installer_2014_51f.msi
