XPMobileSDK compile error in XCODE 12.4
We are facing following error after upgrading to Xcode 12.4
…/XPMobileSDK.framework/Modules/XPMobileSDK.swiftmodule/x86_64-apple-ios-simulator.swiftinterface:615:23: ‘XPSDKConnectionState’ is not a member type of 'XPMobileSDK’
It was working fine with Xcode 11.3
Can anyone help us on this error ?
Hello Revan,
I had a call with the Mobile team, where we discussed the topic and the compatibility with Xcode 12.4 will be possible with Xprotect 2021R1, which will arrive around mid of June 2021.
Will it be ok for you if you bear this with us for one month more?
We apologize for the inconvenience that this might have caused you, but we are aware and are working on it.
thank you for the understanding.
Best Regards,
Milestone
