XProtect 2021 R2 - Open Network Bridge authentication error with FFmpeg
FFmpeg returns this error “method DESCRIBE failed: 401 Unauthorized” trying to use the rtsp urls. (With VLC works)
ffmpeg -i “rtsp://user:pass@x.x.x.x/live/…”
ffplay “rtsp://user:pass@x.x.x.x/live/…”
the windows server 2019 has the policy:
System cryptography: Use FIPS compliant…: disabled
And in the registry, under Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Milestone\
I don´t have Milestone Open Network Bridge so I can´t change SHA256Auth
(https://developer.milestonesys.com/s/article/changes-digest-authentication-RTSP-service-in-2021-R1-troubleshooting)
