Xprotect 2023 R2 camera viewing in Mobile server
Can you please share with me a working example for opening a camera in Xprotect 2023 R2 using the mobile server. I was going through the examples in the SDK from folder [C:\Program](file:C:/Program) Files\Milestone\XProtect Mobile Server\Web\XPMobileSDK\Samples\Video, its so confusing. I did the similar integration before in xprotect 2020 and it was much more simpler. The samples provided are complex to understand in new version.
Could you’ll share me a working example with all the necessary JavaScript’ file’s added in the html file itself rather then importing them dynamically?
Dear Team Milestone
any updates? @Fernando Guzman​ @Bo Ellegård Andersen (Milestone Systems)​
Hi, Devp
Could you give me more details on the problem with the sample, and what you want case you try to resolve? I can give you another sample https://github.com/milestonesys/mipsdkmobile-web/tree/main/Samples/VideoStream but still need more context to help you.
Best regards
Asen Bozhilov
