XProtect Management Essential+ Installation Error
When I the Milestone XProtect Essential+ is being installed, an error message is given in the middle of the installation. The attached log file shows the error detail, however, I could not understand it to be able to solve the issue. I would be thankful if you could help me.
Error: “Could not configure the server.”
