XProtect® software fails to install with "SQL Express failed. Error code = -2068052081
2018/8/13 上午 08:51:16 Error 發生錯誤: ‘Installing SQL Express failed. Error code = -2068052081’。錯誤詳細資訊: 於 VideoOS.Installer.CoSQLExprAdapter.SqlExpressInstallationTask.DoRun()
於 VideoOS.SoftwareManager.Core.Task.Task.Start()
2018/8/13 上午 08:51:17 Error Install failed.VideoOS.Installer.Sequencer.ErrorHandling.InstallerSequencerException: Installing SQL Express failed. Error code = -2068052081
Server stack trace:
於 VideoOS.Installer.Sequencer.SequenceManager.Install()
於 System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs)
於 System.Runtime.Remoting.Messaging.StackBuilderSink.AsyncProcessMessage(IMessage msg, IMessageSink replySink)
Exception rethrown at [0]:
於 System.Runtime.Remoting.Proxies.RealProxy.EndInvokeHelper(Message reqMsg, Boolean bProxyCase)
於 System.Runtime.Remoting.Proxies.RemotingProxy.Invoke(Object NotUsed, MessageData& msgData)
於 VideoOS.Installer.Sequencer.SequenceManager.BeginInstallDelegate.EndInvoke(IAsyncResult result)
於 VideoOS.Installer.UI.WizardPageInstall.InstallationEnded(IAsyncResult ar)
As this does not pertain to development but to a general situation you will most likely get better help from the partners active in the Support Community - https://supportcommunity.milestonesys.com
  1. download SQL Server 2012 Express
  2. execute SQLEXPRADV_x64_CHT.exe
  3. execute Milestone XProtect Professional VMS Products 2018 R2 System Installer.exe
  4. get error
An error occurred during the installation of assembly ‘Microsoft.MSXML2,version=“4.20.9818.0”,publicKeyToken=“6bd6b9abf345378f”,processorArchitecture=“x86”,type=“win32”’. Please refer to Help and Support for more information. 2018/8/15 上午 05:26:04 Information An error occurred during the installation of assembly ‘Microsoft.MSXML2,version=“4.20.9818.0”,publicKeyToken=“6bd6b9abf345378f”,processorArchitecture=“x86”,type=“win32”’. Please refer to Help and Support for more information.
2018/8/15 上午 05:26:04 Information MSI 詳細資料: Action 13:26:04: Rollback. Rolling back action:
2018/8/15 上午 05:27:11 Critical 發生錯誤。錯誤詳細資料: ‘1603’
2018/8/15 上午 05:27:11 Error 發生錯誤: 'Milestone XProtect Management Server (64-bit): An error occurred during the installation of assembly ‘Microsoft.MSXML2,version=“4.20.9818.0”,publicKeyToken=“6bd6b9abf345378f”,processorArchitecture=“x86”,type=“win32”’. Please refer to Help and Support for more information. '。錯誤詳細資訊:
2018/8/15 上午 05:27:11 Information 上一次錯誤: {0}
2018/8/15 上午 05:27:12 Error 發生錯誤: 'Milestone XProtect Management Server (64-bit): An error occurred during the installation of assembly ‘Microsoft.MSXML2,version=“4.20.9818.0”,publicKeyToken=“6bd6b9abf345378f”,processorArchitecture=“x86”,type=“win32”’. Please refer to Help and Support for more information. '。錯誤詳細資訊: 於 VideoOS.Installer.ServerConfiguratorPlugin.ConfigurationTaskInstall.DoRun()
2018/8/15 上午 05:27:12 Error 安裝失敗。VideoOS.Installer.Sequencer.ErrorHandling.InstallerSequencerException: Milestone XProtect Management Server (64-bit): An error occurred during the installation of assembly ‘Microsoft.MSXML2,version=“4.20.9818.0”,publicKeyToken=“6bd6b9abf345378f”,processorArchitecture=“x86”,type=“win32”’. Please refer to Help and Support for more information.
Server stack trace:
It’s ok.
The problem was already solved.
thank you.
using below
  1. windows server 2012 r2
  2. Windows8.1-KB2919442-x64.msu
  3. Windows8.1-KB2919355-x64.msu
  4. sql server 2016 express
  5. Microsoft .NET Framework 4.7.2
  6. Milestone XProtect VMS Products 2018 R2 System Installe(Enterprice)r.exe
